Here's my problem: When pushing the starter button I can only hear the starter relay. Nothing from the starter. The battery is being loaded down to 6 volts when trying to start. Pulled the plugs and verified I could not turn the engine by hand using the flywheel on the rear of the motor. Jet drive is clear of any obstructions.
Pulled the starter, what a pain, Now the engine can be turned by hand. Appears the starter was binding the flywheel ring gear. I tested the starter stand-alone with the battery, turns fine, I did notice the front shaft appears to spin slightly out of round, hum... That's where I'm at. Any known issues with the starter? Thanks in advance..:emoticonb
