Is it possible to replace the top end on a 97 spx without removing the engine from the ski? Are there top end replacement instructions posted somewhere?
97 spx top end replacement
Re: 97 spx top end replacement
Get an OEM Service Manual for that. It's not recommended because you skip a lot of important steps like pressure checking the block - but yes it's possible to do.SBT Tech Support is here to help with your problems.
Be sure to check out the SBT Tech Videos- I have them all downloaded and watched them a few times...they are THE BEST. If you have ANY doubt about the inside of a PWC motor, you won't after watching the videos.
Definitely a must have before you start asking questions about motor stuff.:emoticontI'm a newbie...
The Plan: Back to square one
