Re: 97 SPX Winterizing Procedure (Antifreeze)
This post got way off topic, and I personally apologize.
The question originally asked was simple enough, how to winterize a Sea-Doo 787 equipped PWC with antifreeze. The specific needs of the 787 for winterizing are due to the angled design of the engine and exhaust allowing several large areas to hold cooling water, even when the ski has been drained properly for storage.
There is another general type post that covers the basic information, here it is....
Prior to buttoning everything up and covering the ski, you should do the following:
remove hose from cylinder head to exhaust pipe, fill the head and pipe with 50/50 automotive low-tox® propylene glycol antifreeze until you see the antifreeze coming out of the Cooling System Indicators (CSI's) or "pissers"
Originally posted by Bryan Glynn
SBT Webmaster
SBT Webmaster
