Hey Guys,
My 94 Seadoo SPi runs great and fires right up...when it's cold. Once the motor is all warmed up and you have been riding it for a while it will not turn over, well it does but, very very slow. If you wait 20 mins or so it will fire up again and away you go... What the could this be...? Just desn't make much sence. Why would it run so good and start so easy when cold, but then not turn over when warm..? Must be the starter/solinod..?
Check list:
I installed a new battery..
Checked the cable connections..
Pulled the plugs and turned it over that way, goes a little faster but no real difference.
Turns over by hand easy with plugs out..
I'm going to pull the starter out of it, but I'm really just wondering if anyone has ever seen this problem before...?
Thanks,
Check list:
Thanks,
