My '94 GTX starts and runs perfectly for about 3 minutes, then bogs down and stalls. If it sits for few minutes, it will start and run again for 30 to 60 seconds each time. Does anyone know if this is a common problem with this machine? I checked and cleaned the fuel filter, it had a little crud in it, but didn't change the symptoms at all when I cleaned it. Thanks for any help!
Need help troubleshooting...
Re: Need help troubleshooting...
Rebuild the carburetors!John Kubiak
Las Vegas, Nevada
Sea-Doo Tech 13736
I believe you...but would you mind explaining why these symptoms require rebuilding the carbs? Wierd thing is it ran great up until a few weeks ago....I probably burned 5 tanks of fuel through it in the last month it was dependable....
Thanks for the advice though...
Something like your symptoms could easily be associated with an exhaust leak or a fuel starvation problem.
Fuel starvation can be from a clogged up fuel selector valve, an oring missing in the top of the fuel strainer, a stuck check valve not letting air into the fuel tank, a faulty fuel pump or clogged up carb filters or a few other fuel line realated problems, like a loose clamp, ect.Bill O'Neal <br>
