Please Help!!!! :emoticonb I just bought A 94 spx and when runnig the motor on land It starts fine but the idle fluctuates slightly (1000 -2000 rpms).Also when I first put the Ski in the water It starts fine and runs great, then after I stop riding and let it sit for 10 minutes It will crank but not start.Then if somebody picks up the back of the Ski and gets the Nozzle out of the water and lightly taps the Thottle It will start up and run great at low and high throttle.
Also if I keep trying to crank the motor for about a minute or two you will hear the overheat buzzer then when you get it running and drive off the buzzer shuts off.
I checked compression and found 150 psi in both cylinders.:emoticont What else could I check. :) Please Help!!!!!!!!!!:)
