On the 95 xp, after my daughter gets done riding and shuts the ski off it will usually not start with out pumping the primer 2 times. (I bought it this way). it doesn't matter if its been sitting 10 min or 1/2 hour, it will not start with out pumping it??
Fuel problem?
Re: Fuel problem?
After dealing with this all summer, it's getting both carbs rebuilt in the spring. So I need 2 kits and 2 N&S and set to factory spec. to start. Fresh BR8ES and then run and check plug color. Then tune from there, correct? - But if I can get away and back to the lake this fall I will heed that advice and see how it works! I appreciate it,
Glen
