94xp solenoid conversion kit wiring problem
  • 94xp solenoid conversion kit wiring problem
    I change the new solenoid & brought new conversion kit,I follow the instruction in the manuel but no response at all.Anyone have proper diagram can show?
    :emoticonb
    Re: 94xp solenoid conversion kit wiring problem
    post a pic of how you have it setup
      Did you try jumping directly to the starter motor? Maybe you need a new starter?
        Here is the picture for wiring,must be some connection wrong.No matter how I try after 2 hours still not even a click.I bypass the the solenoid it crank.The solenoid was in good condition.battery fully charge.
        :emoticonb
          You may have a broken brush lead inside of your starter motor.
          Do this. Run a hot wire from the positive side of the battery directly to the positive lug on the side of the starter motor. If the starter works, your problem is elsewhere.
