R.P.M. in RXT. Help!!
  • R.P.M. in RXT. Help!!
    Hello, my RXT does not reach 7.500/8.000 RPM.Accelerator to the maximum and with the sea plate, does not happen(pass) from 6.500/7.000.
    That can be happening(passing)?
    At present the motorcycle has 29 hours.
    I use unleaded gasoline of 95 octanes.
    Is it(he,she) better to use that of 98 octanes?
    Can it be the topic of the petrol the problem?
    One helps please.
    Thank you, a greeting.
    Laski, siempre seras "el jefe"
    Re: R.P.M. in RXT. Help!!
    No I do not think octane is your problem, as the RXT is made to run a regular pump gasoline with octane of 91 or less.
    You could have a slipping supercharger clutch, or some other problem.
      Oil level? If you have too much oil in it, it could cause problems.
      Dan Solie -
        The level of oil I fill this one.
        It marks the level mas highly.
        Who is the appropriate one, in the way of the rod?
          Try a new set of spark plugs if your oil level is correct,should run around the middle between minimum and maximum.
            Ok.I believe that I have passed with the oil. The level is high. It will try to leave it in the way.
            Thank you very much for your answers. Already it will tell you.
            A greeting
              my rxp had idleing issues when i first bought it but it was covered under warranty and it was somcething to do with the throttle cable
              :emoticonb
                That was happening to him in the cable?
                Did they solve the problem?
