The main pipe (TUY.COL.PEINT *TUNE PIPE P. Includes 1 - 4.
274001091 (replaces 274000770) ) of my 2000 Seadoo GTI has developed a pin-hole leak at one of the round weld points. Not sure why, but there are a few of these round weld points on the pipe and each one has this little pin-head size depression in the center of the weld, almost begging the question..."Why would the pipe be desgined with the little tiny welded shut holes in the first place. Anyway, now when the engine runs, water comes squirting out the hole and all over the engine bay. Can this hole be welded shut and the pipe (expensive) re-used or is the pin hole there by degin to let me know that the interior surface has deteriorted to the point it must be replaced. When I look inside the large opening of the pipe, it doe not appear to be rusted anywhere???? I am an amature PWC person with little knwledge of the craft and unfortunately required a few stiches on the right hand when the socket wrench slipped the nut while taking off the pipe assy. :( Any help is appreciated.
