My '91 XP has been running great for a while now. Yesterday I went to start it, it cranked over (at a normal starting speed, not slower as with a low or dead battery) a few times without starting and now all it does is the solenoid clicks. I charged the battery over night but still has the same symptoms. The starter is new last spring. Not sure of what it could be, Please help!
Starting Problem
Re: Starting Problem
You can test the starter motor by jumping a hot wire directly to the positive posts on the battery and the starter motor. If it does not work, replace the starter motor.
If it does make the starter motor work, replace the starter solenoid ( called a relay) in the electrical box.Bill O'Neal <br>
