1995 787 has different drive gears, and will not work in any other model (the same for the crankshaft, also the crankshaft PTO thread pitch is different, and will not work with the later PTO's
Of course if you use a crankshaft, counterbalancer, and PTO from a 1996 or later model in a 1995 engine they will physically fit and work, and vice-versa.
John Kubiak
Las Vegas, Nevada
Sea-Doo Tech 13736
NEVER BUY TIRES AT A "BLOW-OUT" SALE Please do not use Private Messaging, use the forums.
