Seadoo SP starting making grinding Noise
  • Seadoo SP starting making grinding Noise
    After doing work to other things on PWC...I started it...ran fine for a few seconds. Then stopped abruptly...then I tried to restart..It will turn over but not start...I am hearing a Grinding noise coming from starter/flywheel area.
    Any suggestions? You may e-mail
    randyb@koyote.com
    Re: Seadoo SP starting making grinding Noise
    what was you doing before all this happened and where are you in texas kyote .internet is in commerce ant it ????
      I am in Campbell, TX>..I see you are in Sulphur Springs. I had a bad starter relay....I replaced it and it was a success...then after starting once the motor died...I tried to restart and head grinding coming from Flywheel box..
        man I not sure but I bet bill O can help hes good my father inlaw is from there any ways welcome to the forums theres alot of good help here and they can get you going in the right direction??
          Any grinding noise is not something you can fix from outside the magneto cover.
          You need to remove the magneto cover, then the magneto flywheel. You will find one of three things wrong. Either the ring gear has started working it's way off of the flywheel and is rubbing against the front of the engine cases (the ring gear is pressed onto the flywheel), or the flywhell is rusted up badly and the magnets are making contact with the stator, or the stator plate base has broken loose from the cases.
