Hi All, I have bought a 1997 GTX that has a high pitched rattling sound in motor
and will stall out after about 30 mins. of riding. If you change out plugs will run good for 30 more mins. and than stall again. I have had several seadoo's with this same 787 motor and this one has a little more ring sound to the motor .
Like it's just not real tight inside. The previous owner bought it with 42 hours in 2002 and used one summer up to 68 hours when problems stated. He took ski to Dealer and they Installed new Stator, oil pump and lines, rebuilt carbs,removed and cleaned fuel system and cleaned out his pockets too !!
Then they told he that something sound lose in motor and would replace motor for $1500.00, so if you add the $550.00 he had already paid them, He got tired and sold ski to me. Any suggestion where I should start. Have not checked compression. Thought I would start there and move on to Rotary valve and RAVE exhaust valves. This forum helped me greatly in past, just thought I would look for some Ideas ??
Thanks MRG120
Thanks MRG120
