To start I will tell you the problem. My 97 XP attemps to turn over but before it does the starter stops kicking and it repeats this action over and over. If i pull both plugs it turns over fine. Here is a list of things that i have done and checked. Replaced battery, used other batteries, checked rotery valve timing, tried different starter that works great in other jet ski, checked all pins and wires for coreotion and continuity, i have replaced battery cables with brand new ones, replaced sellonoid, taken the whole engine out had just the engine sitting on the work bench and just had starter hooked up to the battery. This motor will not turn over.
Do you know why it wont turn over or can you give me advise on what to do next?? Am I forgetting to do something???
