I just replaced teh starter and solenoid on my 1992 Seadoo sp. The only thing different was the color of the solenoid, Old one was black the new one tan. When I try to start with the button the 5 amp fuse blows. I can jump the solenoid and the starter works. I have checked all my wires and grounds but still no cigar.
1992 Seadoo SP blowing the 5 amp fuse
Re: 1992 Seadoo SP blowing the 5 amp fuse
The 5 amp fuse is fed from the 15 amp fuse after getting power from the rectifier via a red wire coming out of the rectifier. After the 5 amp fuse is the MPEM and Rev limiter. One of those two items is causing the 5 amp fuse to blow. I think you will need to replace the MPEM, unless you find a short somewhere in the wiring.Bill O'Neal <br>
The unit was running great last year. The solenoid was causing the starter to engage while the engine was running thus tearing the teeth from the starter. I replace both the starter and solenoid but after the installation the 5 amp fuse blows. I replace the mpem a couple years ago with the one with not external relays and it's worked great. I was wondering if I used the wrong solenoid. It looks the same and has the same plug from the starter switch but I think it came from a tigershark. The original was black this one is tan. I am trying to clean the corrision from both to verify the numbers. Should I be concerned with the metal shavings from the starter creating a short? The only changes since it was running was the solenoid and starter. The starter works with direct power the solenoid??? Could the solenoid cause the fuse to blow?
I have islolated everything I can think of and still not a clue. I just ran out of 5 amp fuses so I need to get more.
Is there a way to determine if the solenoil is bad? I isolated the switch wires to it and jumped them and nothing happened. Should I be able to energize the solenoid by connecting the two input wires are is there a need to add 12volts? I used to jump my old mustang by just connecting the switch post but I think there was in internal power source.
Good news
Bad solenoid. Yes it will blow the 5 amp fues on a 92 sp.
Lesson learned. Don't buy electrical parts off ebay. A $9 solenoid has cost me a lot of time!
Do you sell solenoids or should I go to my local Seadoo dealer? You have helped the most so I owe it to you
