I just purchased a replacement engine from SBT and was planning on rebuilding my carbs as well. However, when I took the carbs apart, they are basically trashed. They have been sitting around and corroded to the point of no return. I purchased a used set of carbs, but they don't line up with my intake manifold. My question is that if I get the intake mainifold for these carbs, will it fit on my motor? How interchangable are the intake manifolds with other engines?
I have a 95 gtx 657x engine. I believe the carbs came off of a 94 gtx or gt 657 engine. Not exacly sure, but I'm sure they don't line up with my intake.
Will the white intakes line up with the white engines? Is it that simple?
Any help would be appreciated.
