I was riding my 2000 rx for the first time this season and it was running great then all of a sudden it shut off. Once I got it out of the water and home I tried starting it again. It starts turning over ok but once it starts it runs for like 1/2 a sec and it makes this grinding noise. I pulled off some fishing line wrapped around the drive shaft. I pulled off the spark plugs and the rear cylinder smoked a little when I took the plug out. Im thinking that theres no oil getting to the rear cylinder. The spark plug also looks a little burned.
2000 rx engine problem
This topic is closed.
Re: 2000 rx engine problem
