I installed a rebuilt SBT motor engine last summer. After the install it ran perfect. I winterized the ski at the end of last season, and now when i try to start the craft the engine will not move. It seems to be ceased. The battery is charged and is strong. When I try to start I can hear the starter kicking hard and after a bit there is on long beep. I have tried to turn the engine manually after taking out the spark plugs but have had no success. What else should i try to trouble shoot my issue?
1997 Sea Doo GSX
Re: 1997 Sea Doo GSX
If it doesn't turn by hand, it most likely needs to be replced. My first though would be improper winterixation, and rust.
Verify it's the motor by removing the pump and starter. If it still doesn't turn by hand, call in to warranty for a new engine. 877 330 0231SBT Tech Support is here to help with your problems.
