I purchased a reman engine for my 96xp from you guys a couple of months ago, back in the beggining of april. I finally got together all the other parts I needed(old ski replaced a lot of electrical parts) and the time to do the swap. I installed the engine using your book(there are some errors mostly in the suggested sizes?) and a factory service manual and it went fairly smooth. I finally got all the lines routed etc. and all water leaks fixed. It leaked a little water at the ex. manifold but I fixed that with some sealer.
Anyway, the question here is. I finally got it running, no leaks etc. ran it on a hose for a few minutes, mostly to check for leaks. once all was well, the next morning I started it out of the water(it was flooded for some reason?) cleared it out. Plopped it in the water and rode it around at just enough speed to come barely on plane, went through about a half of a tank, it was very rich so keeping speed down was easy. I shut it down and put it up on or lift. Ate lunch came back, lowered it in and it would not turn over, just click, stater solenoid was/is brand new, as is starter. I thought possible hydro lock somehow? pulled plugs and the same thing, wont crank. Removed the plastic pto cover and attempted with no plugs to turn over by hand, it was solid no movement. I used a small pipe wrench and a rag and was able to free it by turning it to the right(sitting on the ski). Spun it over with no plugs, and nothing but air mostly came out of the plug holes. Reinstalled the plugs, and it fired right up, I proceeded with another full tank of fuel and it seems fine, except for a rich midrange issue which is unrelated, same as before.(I think needle and seat/ pop off issue) I thought it possible that the pump may have had a small shell jammed in it or something along those lines,(although the prop is perfect and pump shows no signs?) but that would be a first for that ski(owned it since new) I guess my question is what was the most likely cause? I plan to compresion test it this week, and if you guys alow it pop the head off and take a peek. It is running strong other than the midrange issue and has maybe 2 hours of run time on it give or take. What would be your recomended course of action? I have a pretty vast mechanical knowledge and am very detail oriented but I want to stay within the guidlines of your warranty.
