I just bought a 96 gtx. It cranks and runs good, but when you slow to idle the overheat alarm goes off and no water stream out the rear. When you speed up the alarm stops and the stream starts back. the engine seams to be hot and it is hard to crank while hot almost like it is vapor locked. when engine cools it cranks right up.
96 gtx overheating
This topic is closed.
Re: 96 gtx overheating
