My 94 SP flooded and sucked up water. I stopped it and removed the plugs. Sure enough there is water spraying out of the S plug hole when I crank. What do I need to do? Is it a complete engine strip or if i clear iut the intake and the ports will it be ok?
My SP has sucked up water
Re: My SP has sucked up water
Watch the Ride Right Video: http://www.pwctoday.com/showthread.php?t=68444SBT Tech Support is here to help with your problems.
