XPS Oil just hit $50.00 a gallon at the only seadoo dealer in my area. This is insane!!!! This red line oil is available on line for $30.00 a gallon including shipping. Anyone see any problems running this in a 1997 787 rave carbureted or a 1996 717?
Red Line All-Sport Two-Stroke Oil
A biodegradable lubricant designed for air-or-water-cooled performance engines which require a low-ash oil, not an NMMA TC-W3 lubricant. Better production of power, scuff protection and bearing protection is obtained compared to petroleums and other synthetics and is incredibly clean. Perfect for new reformulated and oxygenated fuels.
Two-Stroke AllSport
™ - is a high-performance all-synthetic formula which is designed to provide maximum power and the greatest protection and cleanliness in watercooled and air-cooled two-cycle engines. Uses a low-ash chemistry which provides better cleanliness in higher temperature air-cooled engines, while the Water Craft Oil provides better cleanliness in lower-temperature water-cooled engines. Recommended for high-performance stock or slightlymodified engines and where ISO GD, JASO FC, or API TC lubricantsare recommended, but is not designed for outboard use. RedLine AllSport™ Oil may be run in ratios between 16:1 and 100:1,
