Ok smarter than me guys! I got a GSX 787 in the shop! It had the crank bearings locked up got it to turn and did a compression test. 120 lbs per cylinder I called you guys and ordered a new crank. Carb kits, RAVE kits. Put new crank in and installed into boat. Within seconds demolished the top end. I found that the RAVE valve hit the rings. I figured that i must have done something very wrong in the install. So i pulled the motor again and could not find what that wrong was. I installed a new top end and reinstalled in to boat. I turned it over with the head off and with the head on with no problem. Then installed plugs and fired her up. Lasted about a min then she droped to about 60lbs on the rear cylinder again! I have not returned to disasemble the top again but after pulling the plugs I pulled the RAVE caps and pushed down on the RAVE vavle and can feal it hit! Suggestions PLEASE!
1997 GSX 787 New SBT Crank
Re: 1997 GSX 787 New SBT Crank
That doesn't make sense unless you installed uncut RAVE vales into a oversize bore top-end, or you put the pistons in backwards, or didn't install the rings correctly. What did you do with each of those?SBT Tech Support is here to help with your problems.
I know that it does not make sense, The pistons are stock bore 82mm! The top end was perfect before i started. The only thing I did was to change the o-rings and baffels for the valves and clean. Is there any type of timing issues that you can think of? I am at a loss as to what to do!:emoticonr
The boost port has nothing to do with piston alignment. You align pistons by the arrow on the top. On Sea-Doo's it always goes towards the exhaust port. On your particular engine that is also the intake port side. The boost port happens to be on the opposite side. If you installed them backwards, you simply snagged the ring on the exahust port.SBT Tech Support is here to help with your problems.
