Before I order this gear, I need to know what usually goes along with replacing this gear so that I don't get into it only to find I need other parts to finish.
thanks,
Rob
'94 raider 700S The question is........Who's the hottie on the main page?
We never recommend just doing the gear. When the gear strips, the shaft is almost without fail, bent as well. I suggest getting a whole roatry shaft assembly. Other than that, it's just cleaning out the debris from your engine and changing your oil and filter.
I mean change the oil and filter - it gets contaminated from all the brass shavings.
I'm assuming there was a filter in-line somewhere. Therein lies the problem and a glimpse into what has happened. My buddy was all gung-ho about converting to premix in which he applied the Yamaha method to my Sea Doo. I had no friggin' idea what he was doing b/c I didn't know anything about pwc's..........he says he does.
He proceeded to eliminate all the lines and hoses, pulled the oil res. out and threw it all away. The next day I printed off the instructions from SBT's site b/c I wasn't comfortable with not knowing what he was doing. I went back over there the next day and pulled my tank and anything else I could find out of the trash. However, I failed to read close enough and did not connect the top oiling hose ( but the bottom one is)...hence the failure of the gear.
So with that said, there is no filter, no pump, no stock lines and 3/4 tank of premix b/c it only took maybe 30 minutes of actual riding time to fail.
Does SBT sell filters? - I couldn't find it. I'm kind of thinking of installing a new pump and going back to injection............it's a disaster!!
The filter went to the pump, so you don't need it now. Just get your tank and the large case lines connected and filled.
