Hello I am working on a 99 Doo Doo Challenger 1800,I am rebuilding the carbs and I just want to get as close a I can with getting the carbs adjusted to where they should be too the specs,so if someone could be so kind enough to give the specs I would appreciate that,Oh and one more thing about the fuel pumps,they are not part of the carbs,they are mounted up on top of the flywheel housing cover,and are mechanical pumps still utilizing the case pulse.Thankyou for your help in advance.
Carb Concern 99 Challenger 1800
This topic is closed.
Re: Carb Concern 99 Challenger 1800
