winterizing 01 seadoo xp
  • winterizing 01 seadoo xp
    I was told to "de-fog" the engine and to drain the gas out of the seadoo to winterize it. Is this correct. And if so how do i "de-fog" the engine? I cant seem to find the carburator on it, and the manual is no help to me. Thanks
    Re: winterizing 01 seadoo xp
    Someone mis-spoke or you heard wrong. You need to fog the engine, as part of winterization. The procedures are here: http://server1.sbtontheweb.com/forum...ad.php?t=13977
      Thankyou. The instruction were very helpfull. Only addition question i have is that i cannot locate the carburetor on the machine. Is there anyway you could describe it, or take a picture for me? The manual i have is absolutly no help. The maschine i am asking about is a 2001 Seadoo XP. Thanks
        The carbs are right under the bog black plastic airbox. You don't need to get to them, you will see a little plastic nub that you pull out on top of the airbox, that's what you put the little plastic straw of the fogging oil can into, to fog.
          So if i don't winterize how often and how long should i run my ski?
            Living in houston our winters are mild and short, is this really nescessary?
              If you are in a warm climate the only things you need to worry about is fogging if it will be unused more than 4 weeks at a time, and stabilizing the fuel if it will be stored more than 2 months.
                thanks for the info.
