What is required to winterize a 2005 GTX that is supercharged. I know about fogging the heads, stabilizer in the fuel, and removing ther battery. Is there anything else?
Thank You
Alan
Thank You
Alan
Fogging has nothing to do with fuel injection. The oil is sprayed in the intake.
To fog a 4 Tec motor, you remove the fuel rail and fuel injectors and spray the oil directly into the intake ports, then while holding the throttle wide open, you crank the engine with the starter motor while still fogging it.
As fully detailed in the winterization tech article...
