Would like to know if there is a alternative fuel tester tool that will read the psi on the fuel pump. I don't have a manual but was told the psi should read 42psi. If you have a PN# for a alternative tool great. or what is the BRP PN#. I broke my fuel tester trying to test it not knowing the fuel psi was that High. thanks
4TEC Fuel PSI TESTER PN#
Re: 4TEC Fuel PSI TESTER PN#
The correct fuel pressure right off the fuel pump should be 44 psi with just the lanyard installed, then it needs to remain at 44 psi once the engine is running.
Any fuel pressure guage with the right capacity will work. The oem recommended guage that they sell goes up to 160 psi. But any automotive fuel pressure guage should work. The oem guage comes with the correct hose fitting to hook it up to the 4 tec fuel system.Bill O'Neal <br>
