95 speedster hull repair
  • 95 speedster hull repair
    I bought a 95 speedster and the thru hull where the drive shaft sleeve attaches on the inside is broken. I saw a repair sleeve being sold on the internet. Is there different sizes? If so, what size do I need?
    Thank you in advance for your response.:emoticont
    Re: 95 speedster hull repair
    Try www.worldofpowersports.com. They have parts diagrams you can look at and locate the part and part #. I bought those same fittings for my '95 speedster there.
      Thank you. I found the site useful and located the part I need. Did you have much trouble installing them? The outside surface of the thru hull is chipped. Do you think this might cause water to leak into the bilge?
