I have a jet pump on a stick.
I can't get the driveshaft out of the impeller on my 97 SD GS. It's been in salt water and the shaft is pretty corroded.
I have tried WD-40 and light hammering. I am afraid of damaging the pump bearings if I whack it too much. I can't get any purchase on the shaft without directly stressing the impeller shaft and bearings.
Do I have to remove the impellor first, then whack away?
What if I cut off the plastic bushing between the impellor and the driveshaft to get more WD40 in there?
Anybody have any ideas out there please?
Thanks in advance.
Thanks in advance.
