Help I put wsm wear rings in my 95 & 96 xp's The leading edge of the prop is touching the ring on both pumps. One prop is stock other is a nujet. You can turn by hand but they are very tight. Is this normal or is something sound wrong? thank you for any help
seadoo wear ring tight?
Re: seadoo wear ring tight?
I found this out a few years ago. This is totally normal due to the plastic seadoo pumps flexing when you tighten them down. They distort, thats why you probally saw a few shims under the pump lips.
I sprayed some lube on the wear ring and impeller and fired it up. Do the same and you will be just fine.
