XP Limited 1999 VTS Not working... Help please..
  • XP Limited 1999 VTS Not working... Help please..
    Hello,
    Today, I noticed that my VTS isn't working anymore. I Removed the cover and nothing is wet and connection are OK. When I press up or down, I hear a 'CLICK' on the VTS motor.. Any idea what is the problems ? As I hear a click on the motor, I assum all the connection are good.
    Any help would be appreciated because a motor is like 300$... :(
    Thanks!
    Re: XP Limited 1999 VTS Not working... Help please..
    removing the cover to the VTS does not tell you much. remove the VTS from the shaft and test it to see if the shaft is stuck or the gears in the motor are frozen. If the shaft is stuck you will need to remove it clean and relube it, then align it. If it's the gear box and motor you'll have to replace it, unless you do not want to use it, and in that case alline the thrust for a level shot and put VTS motor back in and leave it.
      You know what it was.... the 7.5 fuse was blowed. I replaced it and now VTS is working. I'll see if it will blow again, if not, it was a fairly easy fix.
      Regards,
