I have a 2000 Sea-Doo boat with (2) 717 Rotax motors and I would like to run with out the oil injection system. Granted I'm new to the Rotax motors, but I understand it is possible? I just feel more at ease knowing the oil will be getting to motor knowing it is already in the mix. I was also told that keep in mind that the crank case on these engines must have oil? I assume by looking at the injection system as it is now the oil comes from 2 cycle oil tank. The question is if I install the block off kits and do away with oil tank and hoses how will I accomplish getting oil in the crank case or keeping there? Are should I just remove the line that feeds the pump and leave every thing else the same?
Oil Block off kit
