Hey there everyone i am a new owner of this pwc & this is my first post.I took it out for the second time & the vts stop working.I check the fuse & it was blown, i then put another 7.5 in & that one blew.So i put a 10 in & it didn't blow but it did not work either.So i took off the cover to the vts & there was a little water in there but not much.So then i tested the motor straight to the battery & it did not work.Do i need a new motor or is there something else i need to try or do different?If i need a motor is it hard to do myself & where can i get one?Thanks ahead of time,Andre
97 Gsx Vts Problem
Re: 97 Gsx Vts Problem
Everything you wanted to ever know about VTS:
http://www.sea-doo.net/techarticles/vts/index.html1996 Sea-Doo HX (Owner)
1996 Sea-Doo GTX (Surrogate Owner)
