electrical problems
  • electrical problems
    I think I have a shorted out stator. I have the stator and housing off the motor. I used an ohmmeter with one probe on the housing and the other touched the leads from the stator (3 yellow and 1 black). On all leads the meter swings to 0. Does that mean the stator is bad?
    Note: battery discharges when hooked up but if I disconnect the wire plug for the stator/pickup it does not discharge.
    I think the ski is a 96 year model. The hull # is ZZNL0401E696 5620. The motor serial # is 4781451. It is a GXS. Can someone please confirm the year and engine size from these numbers?
    Re: electrical problems
    Seadoo 800 motor..... Blue and white seadoo GSX. Put your OHM meter on "contitnuity test" and see if any of the yellow wires have continuity to ground. They shouldn't!
      thank you much. All 3 yellow wires read a short to ground. I am stator shopping.
