2000 gtx di and Break in oil
  • 2000 gtx di and Break in oil
    I just had the top in done on my 2000 gtx di and when i ordered the kit SBT also sold me some break in oil but now i am reading on some other web sites that i should not put the break in oil in, so now i dont know what i should do, do i need to drain the gas that has the oil in it out of my seadoo? or will it be ok? and if i do drain it will a little bit hurt it if i dont get it all out? I was planning on taking it out today for the first time so any help would be great.
    Re: 2000 gtx di and Break in oil
    No, you can not pre-mix a DI engine. Put the oil system back if you removed it and get the pre-mix fuel out of the system.
      I drained it but there is still just a little in the bottom of the tank do i need to get that out also? And what do i need to do about the gas in the lines?
        I wouldn't worry about that.
          Ok and thanks again for your help
