hello any one knows how to fit this problem i just instal a new motor on sea doo 2000 gtx rfi i put it on time the gas is flowing and compression is 125 each side but nothing can any one can helpm me this
2000 gtx rfi crank but not start
Re: 2000 gtx rfi crank but not start
From that description it would indicate a lack of spark, and the first thing to check there would be your battery. Put a multimeter ont he battery while you are cranking it over, and read the voltage. If it drops below 12.2 the ignition will shut off. That would indicate a bad or discharged battery.SBT Tech Support is here to help with your problems.
