I just got this 1995 Seadoo Speedster. As far a I know it has just been tuned up but I am starting to wonder. I am new to boating.
Starts up and runs great. idles evenlly. The two throttle levers are not synchronized and that is really annoying.
The problem i am having is when I accelerate both engines at full throttle the Starboard Engine will reach about 4,000 rpm or so and then die back to an idle while the Port engine continues to 7k rpm thus giving me a 30 mph top speed or so. If I do not go wide open it seems to do ok.
Also, is it a good idea to tie both accelerator linkages together?
I hear alot about the premix thing. Should I be doing this.
Last couple of things:
I am going to bring my boat to the shop for service soon. What should I tell them to perform or will they know this already. i.e. fuel, oil filters, jet pump oil, engine oil. (Is there two different oil changes? Jet pump and Drive?) I am very confused.
Last but not least. I notice when I put the boat in the water I will get some water coming in to the deck area then it drains back out. There is always a little on deck though.
Thank You
Carmine Cupani
Thank You
Carmine Cupani
