I purchased a 93 Seadoo SPi (Jul 04 SBT rebuild) about 4 months ago. Since buying, I have changed the pump oil, removed the oil injection pump and converted to premix, re-attached the lower crank case to the engine support bracket (it had been held on by 1 loose nut), checked the gap and cleaned the plugs with 800 grit sand paper, and lubed the PTO / drive shaft and carrier seal grease fittings. I have had the ski out 4 times and runs smoothly at idle and 3/4 throttle. Just a little shake at WOT.
Next project is to clean and rebuild the carb. Before doing that, I want to remove the gas tank and clean thoroughly, change the fuel filter, possible change the fuel lines, etc.
Q's: Can I get the fuel tank out through the forward access hole? Do I need to remove the oil tank to get the fuel tank out? Does the fuel tank even need to come out? Any suggestions welcome.
