Hi Have a question on tool tolerences, purchased the tool new, went to algin
the motors and found as i rotate the shaft the tool would go easy in one position only,and bind in all other positions so I put the tool in my v-blocks with a dial indicator i got this
as rotating the shaft, out of round .047 at 1/2 inch back of tip, up and down
deflection .040, I position the mounting plate at the same distanance as it would be in the skies 98'spx-00'rx, with all the concerns on alignment after
motor replacment not sure if i should proceed at this point.
Thanks for any input don:)
