This is my first post, so be gentle. I have been boating for 20+ years and finally bought a jetski to play on the water with. I have alot of friends that ride, but now I have a reason to join them.
At any rate,
I picked up this ski pretty cheap but obviously it needs a little work.
The VST is not working, and I wanted to check the fuses, but I can not get the fuse box out to open it and check the two fuses.
If I try to bring the box to the stern of the PWC it appears that the exhaust clamp will not let it come through.
The exhaust was removed to weld the freeze out plugs ( I guess that is what they are called). How is the fuse box supposed to be moved?
Once the fuses are inspected, I can begin to troubleshoot the vst problem. The VST cable looks like the sheathing is broken and rusted, so I know that has to go. I want to disconnect the vst motor and test it without the cable attached as I think that cable might be causing the motor to lock.
Next up is the fuel lines. I own 4 boats so Iam familiar with the troubles with E10. The tank was replaced last year, but I am not sure if the fuel lines were.
They look fairly new (gray in color). The fuel filter was clogged with some reddish colored dirt (not rust) and had some phase seperation from the e10 and water in the bowl.
I drained the tank and there was very little water or dirt in the tank.
Is the reddish dirt an indication of the lines breaking down?
At any rate,
