flushing the cooling system
  • flushing the cooling system
    I need to flush the cooling system on my seadoo (gtx supercharger). how do I flush it out?
    Re: flushing the cooling system
    Remove the allen head screw in the back of the ride plate and drain it out ,also remove the coolant tank cap to help with the flow. Install new coolant after you replaced the allen screw. After it seems like the tank is filled back up, then remove the drain plug again to let any air escape out of the system, then put it right back in and snug it up. You will have to top off the tank after the first 1/2 hour of use. Tom SBT tech.
