94 SPX project
  • 94 SPX project
    I am searching for info on performance upgrades for this 94 SPX I'm fixing up. My first big question is are there any special details I need to consider if I remove the oil injection and oil tank. It seems like I can just remove the oil pump, lines, tank, etc. seal all of the holes, and just start pre mixing. Is this OK, and If so what ratio would you reccomend? I dont trust the oil injection, especially since the pistons were burnt up and the lines are so old. The other thing is the exhaust, Factory Pipe seems to be my best option, but I dont want to buy a new one, its 800 bucks. Anybody got a used one? Thanks!
    Shantico
    Re: 94 SPX project
    Oil pumps dont fail as often as every one seems to think, If you switch to pre mix then you have to loop the line that feeds the rotary shaft or leave the oil tank connected to these hoses. First thing you should do is replace all of the fuel lines and go through the carbs. Tom SBT tech.
      Re: 94 SPX project
      Thank you for the info on the oil injection. That will be very handy. Any info on my exhaust question? Also what should I set my high and low speed jets at when reinstall the carbs? I am very conserned about this motor running to lean, these pistons are burned up pretty bad. thankyou
      :beer
      Shantico
        Re: 94 SPX project
        Jetting, low speed 1 and 1/4 out +or- high is 3/8 out . cant help you on the pipe but if you do replace the stock one you will have to re jet. Tom SBT tech.
          Re: 94 SPX project
          Thanks Tom, your tons of help. I am upgrading the hood because its cracked. Will a 1999 black SPX hood with mirrors fit on the 94 SPX hull? They look like the same basic shape. Thanks
          Shantico
            Re: 94 SPX project
            Yup, it'll bolt right on.
            Dan Solie -
              Re: 94 SPX project
              I have a 94 xp with a good motor if you are interested.it will be a good deal.
              Diapers and politicians need to be changed often and for the same reasons.:beer
                Re: 94 SPX project
                I am interested, send me some pics and some info and maybe we can get a deal together. Thanks, Shane (stonehousesurfaces@yahoo.com)
                Shantico
