The PTO rave valve on my 97 gtx was leaking oil externally really bad so i removed it to clean it and was just wondering what should i use. I was thinking maybe brake clean, mineral spirits, or top engine cleaner, but im not teally sure. also how should i clean the rave bore. Thanks.
Cleaning rave valves
Re: Cleaning rave valves
I second the carb cleaner.. It's liquid magic! For built up gunk I also take the rave paddle to the wire wheel and give her a good cleaning.
To clean the rave bores, you will need to use a small soft wire pipe cleaner. use WD-40 for this though, since you really don't want carb cleaner degreasing /de-oiling your bearings.Dan Solie -
I cleaned the raves with carb cleaner, and i cleaned the bore with carb cleaner also, i did it right after sbt posted, when i was done i pulled the plugs and turned the motor over to try and clean all the carb cleaner out of the cylinders. then i put everything back together and it backfired really bad, so bad that i couldnt hear out of my left ear for the rest of the day. then the motor started and seemed to run fine. i took it out to the lake yesterday to see how it runs and it seemed to run pretty bad. from a dead stop i would give it full throttle and the rpm would stay around 5000rpm. if i stayed in it it would eventually go to around 6800 rpm, or if i let off and went back to full throttle. and sometimes i would give it full throttle and it would go like its supposed to.
All the fuel lines have been replaced, and the fuel filter is clean, and i cleaned the carb filters about 3 months ago.
You must have sprayed a large amount of carb cleaner into the ports to get some serious back firing. Try changing plugs tell us how you make out. Tom SBT tech.SBT Tech Support is here to help with your problems.
