96 GTX High RPM Slow Go
  • 96 GTX High RPM Slow Go
    Hello all, just joined forum and have read about half the posts in this section. I think from reading i may have a wear ring issue. I have owned the ski since new and have about 130 hours on it. Didn't use at all last season and took it out yesterday. Started up with no problems and ran fine for about 10 minutes, then started losing speed but rpm's stayed at about 7k. Shut it down fairly soon after problem, would idle ok but very slow out of hole and not much top end. Have never worked on skis but probably need to give this a shot myself. Where would I find details on replacing wear ring if that's the issue and any other suggestons would be appreciated.
    Re: 96 GTX High RPM Slow Go
    Remove the jet pump and inspect wear ring also you might have a issue with the impeller splines or coupler and drive shaft splines being worn out. Tom SBT tech.
