1997 Seadoo GS Will not full throttle
  • 1997 Seadoo GS Will not full throttle
    My Seadoo will not hit full throttle without sputtering. I had this issue before and was forced to rebuild the carb. I am in the process of rebuilding it again. If after this rebuild the problem still exists, any idea what else I could check. Thank you,
    Ron Kareiva
    Re: 1997 Seadoo GS Will not full throttle
    Try new plugs. I was having similar symptoms with my GSX, and that fixed it.
      check the high speed adj screw make sure its inspeck if dont have a manual try to do a plug chop
