The engine quit and the crankshaft would only turn 1/4 of a revolution. Upon disassembly I discovered that the leading edge of the rotary valve had a 1/8" long cut through the leading edge at 90 degrees from the leading edge. Also the cut edge had been bent in toward the engine block so that the bent/cut edge was hanging up in the front cylinder intake port behind the rotary valve. I can see where the cut edge of the rotary valve has put a small gouge the face of the block at the edge of the front port that I can file smooth, and there is a similar, but more minor scratch in the face of the rotary valve cover at the edge of the hole which abuts the front port which can also be filed smooth. After I removed the rotary valve, the engine rotated freely.
Does anyone know what could have caused this? What should I look for as a possible cause? Can I just reassemble the engine after installing a new rotary valve? This has me completely baffled.
Thanks, in advance, for your help.
