There's a small retaining clip on each of the spark plug wire connections to the coil in the ignition box. I'm changing out the ignition box cover because the locking tabs are broken so I'll have to separate the wires and coil. When I R&R the plug wires to the coil, I'm sure I'll mess up the retaining clips.
The problem is I can't seem to find the retaining clips on any of the online parts diagrams (including SeaDoo.com.) I've got to believe this part is pretty common across the various Sea-Doo models. I've even called a dealer with no luck. I'm beginning to doubt my sanity. Maybe too much leaning into the engine compartment and breathing fumes has fried my brain!
If anyone knows the part number I would be very grateful for the information.
Thanks!
Thanks!
