I apologize in advance for the long post. I just bought my first seadoo. It's a 00 xp. Guy says it runs great. Went to get it, looked at the prop(looked great) and checked the compresion(125 on both cyl, good?) paid they guy and left. Got it home and started it up and the tach just pegged to 8000rpms. Do some searching and find a lot of high rpm problems related to wear rings. So I go back out and crawl under it and look at the prop and it looks like the only part of the wear ring that is left is about 2-3in around. Started to get ticked. Went inside and did some more reading. From what I gather the clearance between the outside of the prop blades and the inside of the wear ring is suposed to be no greater than .040 ?. It looks like mine is over an 1/8! Now I'm fuming. Call the guy the next morning and he says it always does the idle thing until you put it in the water and it ran fine the last time out. Next day I go to the lake and low and behold the thing runs like a scalded dog. I have seen many posts saying that their motors are turning high rpms, but the ski doesn't go or goes slow and the answer seems to be a wore out wear ring. My question is if my wear ring is mostly missing how is it running so good(60 on the dreammeter)? Also it idles about 2000 in the water. What could be causing such a difference in and out of the water? Any other things to check out would be appriciated.
